So,
I have 8 GB of RAM, Windows shows this http://prntscr.com/a58xya, BIOS shows that I have only 4 GB of RAM.
I tried to reinstall RAM sticks one by one. One works and PC boot normally, the other one seems that it's not working because PC wont boot. (I tried both slots)
Now, my question is why is Windows showing 8 GB of RAM installed if the other 4 GB of ram is not working?
The sticks are the same brand/type, etc.
https://linustechtips.com/topic/550962-problem-with-ram-memory/
The RAM is probably throwing an error preventing the system from booting up if there isn't also the good stick of RAM in the system (memory issues can be pretty finnicky). So The bios is detecting the working RAM while windows is detecting total RAM. (Windows is also only showing 3.46gb usable)
I would recommend RMA'g the broken stick.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/550962-problem-with-ram-memory/#findComment-7272083
