1 hour ago, tezgaming said:
I
Here, better CPU, better GPU, and USB 3.1, if your budget is a fair bit higher, go for a 380 GPU
PCPartPicker part list: http://ca.pcpartpicker.com/p/YBzr3C
Price breakdown by merchant: http://ca.pcpartpicker.com/p/YBzr3C/by_merchant/
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($168.75 @ shopRBC)
Motherboard: Gigabyte GA-H110M-S2HP Micro ATX LGA1151 Motherboard  ($93.98 @ DirectCanada)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($51.50 @ Vuugo)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($68.15 @ Vuugo)
Video Card: MSI Radeon R7 370 2GB Video Card  ($169.98 @ NCIX)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($39.99 @ NCIX)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($55.10 @ Vuugo)
Total: $647.45
Generated by PCPartPicker 2016-02-19 05:35 EST-0500
