If you just need it for temps, I just realtemp. It's a free program
I would use it for getting average temps, i use HardwareMonitor for temps
Breaking things 1 day at a time
https://linustechtips.com/topic/550732-replacement-for-aida64/#findComment-7270056
Idk then. Personally I think idle temps and load temps are the only ones that matter so realtemp or hwmonitor will suffice. You could always buy Aida. Intel XTU might have temp readings but I'm not too sure. Haven't used it in too long.
https://linustechtips.com/topic/550732-replacement-for-aida64/#findComment-7270060
Like I would need it as a stress test. Sorry for not specifying
https://linustechtips.com/topic/550732-replacement-for-aida64/#findComment-7270066
https://linustechtips.com/topic/550732-replacement-for-aida64/#findComment-7270067
Ok. I think i have tried it before and it isnt c0ompatable with AMD
Ohhh yeah forgot about that. You can use Prime95 along with realtemp or hwmonitor.
https://linustechtips.com/topic/550732-replacement-for-aida64/#findComment-7270076
