MasterCase Pro 5 EATX compatibility?
Solved by Inception9269,
On 2/19/2016 at 7:25 PM, nialdz said:
Works beautifully, with AC too. It's a bit pricey but judging from your choice in components budget isn't much a problem, and the heatsink on it is red.
I found a solution to my problem. People in my house were having trouble with the wifi not going far enough so I bought a wifi extender, however they decided it was no longer needed so I kept it. It has an ethernet port so I was curious if it could be used as an output (wasn't sure if it was made to be connected to the internet router) but apparently I can use it as an output. So i have it set up next to my pc and wifi hotspot, the wifi going to the extender and from the extender ethernet to my pc and it works perfectly. In addition to that I think my latency is faster
