Help upgrading 2 embarrassingly old rigs
Solved by Dabombinable,
Just now, Reverof82 said:I found this on newegg.com... I know it's not an SSD ... but this lot is only $290
GIGABYTE GA-F2A78M-HD2 (rev. 3.0) FM2+ AMD A78 SATA 6Gb/s USB 3.0
AMD A8-7670K Godavari Quad-Core 3.6 GHz Socket FM2+ 95W
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600
WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5
That'd be a good upgrade, and if its all in working order, a very good deal.
