Hi, I'm creating a build and I noticed that the motherboard has two Ethernet slots.
I'm seeing people state "Basically you can double your throughput of your LAN connection if your hardware supports"
I'm using an Nighthawk R7000 router, I'm not sure if it supports "double teaming" that I read. Can somebody help me? Would I benefit from connecting two Ethernet cables from my router to this new setup? Let me know, thanks!
https://linustechtips.com/topic/550182-dual-lan/
It doesn't hurt to try for yourself.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
https://linustechtips.com/topic/550182-dual-lan/#findComment-7263870
"Double Teaming" has many different names, some people call it "Nic teaming", others call it "Link bundling", but it's really called Link Aggregation.
Looks like it should support it.
Using Link Aggregation will just increase your LOCAL network speed, not your actual connection to the internet.
It's useful if you've got a NAS or such that needs to have fast transfer speeds, that way the connection to it is less of a bottleneck. (assuming that the disks in the NAS and the PC that is utilizing it are able to read/write faster than 1Gb/s or 128MB/s (Which is around what most HDDs are, some range up closer to 200MB/s, others are down below 100MB/s, though SSDs typically are near 500MB/s or faster, so you'd definitely benefit from link aggregation if you've got an SSD NAS and you've got an SSD in your rig with only a 1Gb/s connection)
https://linustechtips.com/topic/550182-dual-lan/#findComment-7263875
99% of the time link aggregation is not going to help the home user. The only case in which it does is if you have a home server/NAS that you want a faster connection to, the only time I have seen it be worth it is in my media server with multiple clients accessing 1080P streams at the same time + 720P security cams. I would say that it is probably not necessary for you to do but if you are wanting to try it for fun/learning than go for it! Networking is a lot of fun to learn! If you have any more questions about it feel free to ask me!
(NOTE: I doubt your router supports LACP or any type of LAG for that matter. You would probably need to purchase a managed switch which are usually upwards of $50 for a cheap 5 port model and $100+ for a good 18-24 port model.)
https://linustechtips.com/topic/550182-dual-lan/#findComment-7265916
also be sure
managing a managed switch sounds easy ;).
This project would be nice to get some knowledge about that and experimenting stuff.
- but if you dont use any server or other local hosting stuff (NAS/etc) it wont make sense. You also have to know that if you want to copy double speed the other hardware has to have a dual (LACP) channel, too
https://linustechtips.com/topic/550182-dual-lan/#findComment-7273186
Most of these folks are correct regarding 802.3ad Ethernet bundling: you need to make sure both ends of the connection support it.  In this case, that's your PC or server, and the network device it's connected to.
Assuming you have a server with resources on it, bundling can help if and only if you have multiple possible clients trying to access it simultaneously.  The network device upstream from the server can hash the connections over the aggregated bundle to the server and try to use both links equally (it'll never be 50/50).  However, if you have a single client (eg: a PC) talking to a server, neither end will benefit from a bundle.
Editing Rig: Mac Pro 7,1
System Specs: 3.2GHz 16-core Xeon | 96GB ECC DDR4 | AMD Radeon Pro W6800X Duo | Lots of SSD and NVMe storage |
Audio: Universal Audio Apollo Thunderbolt-3 Interface |
Displays: 3 x LG 32UL950-W displays |
Gaming Rig: PC
System Specs:  Asus ROG Crosshair X670E Extreme | AMD 7800X3D | 64GB G.Skill Trident Z5 NEO 6000MHz RAM | NVidia 4090 FE card (OC'd) | Corsair AX1500i power supply | CaseLabs Magnum THW10 case (RIP CaseLabs ) |
Audio:  Sound Blaster AE-9 card | Mackie DL32R Mixer | Sennheiser HDV820 amp | Sennheiser HD820 phones | Rode Broadcaster mic |
Display: Asus PG32UQX 4K/144Hz displayBenQ EW3280U display
Cooling:  2 x EK 140 Revo D5 Pump/Res | EK Quantum Magnitude CPU block | EK 4090FE waterblock | AlphaCool 480mm x 60mm rad | AlphaCool 560mm x 60mm rad | 13 x Noctua 120mm fans | 8 x Noctua 140mm fans | 2 x Aquaero 6XT fan controllers |
https://linustechtips.com/topic/550182-dual-lan/#findComment-7273648
