Hey Forum
In a couple months I will be buying a Curved 34" 3440x1440p Ultrawide monitor that runs at 75hz. Right now I have one EVGA GeForce GTX 970 4GB FTW Edition card which is an absolute beast but I'm only running a 1920x1080 monitor. I'm just wondering and curious to whether or not throwing in another card in SLI will be enough to handle the workload. Thanks for the help!
https://linustechtips.com/topic/549510-will-970-sli-be-enough/
Yes thatll be fine. A single 970 can run 1440p but not sure if the ultrawide aspect would affect much.
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/549510-will-970-sli-be-enough/#findComment-7256207
It will be enough, it would be enough to do 120 Hz probably, so 75 Hz is fine
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/549510-will-970-sli-be-enough/#findComment-7256318
I would opt for 980TI, possibly 980TI SLI... 1440p ultrawide is demanding and even x2 980TIs can struggle with certain titles.
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
https://linustechtips.com/topic/549510-will-970-sli-be-enough/#findComment-7259883
