Yes, it's plenty.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/549058-enough-power/#findComment-7251195
8 minutes ago, smiles rising said:
how do you calculate this stuff? on nvidias website is says 600w or more for the 980ti..
Guess what, for safety reasons. There are always ppl out there who buy 5$ PSU from the local shop or reuse an ancient one and in these cases 600W+ is recommended. Nvidia also states that it cannot consume more than 250W (w/o OC) which is easy math. A modern PSU with sufficient connectors will be surely enough.
https://linustechtips.com/topic/549058-enough-power/#findComment-7251336
Just now, Erwylh said:
Guess what, for safety reasons. There are always ppl out there who buy 5$ PSU from the local shop or reuse an ancient one and in these cases 600W+ is recommended. Nvidia also states that it cannot consume more than 250W which is easy math. A modern PSU with sufficient connectors will be surely enough.
ok great, im glad that i bought a psu that doesn´t suck
Watches and computers
https://linustechtips.com/topic/549058-enough-power/#findComment-7251344
2 hours ago, smiles rising said:
i currently have a EVGA G2 SUPERNOVA 550W and im wondering if this is enough for lets say a 980ti in case of a GPU upgrade? is it enoguh or do i need a new psu then?
You're more than OK.
https://linustechtips.com/topic/549058-enough-power/#findComment-7252263
Just now, JoeyDM said:
You have more than enough headroom. All of the calculators are shit, you kinda have to go by experience.
but lets say if i want to upgrade my cpu and gpu should i just hope i have enough power and if i dont i buy a new psu?
https://linustechtips.com/topic/549058-enough-power/#findComment-7252347
No you should come ask us :P
If you want to get a better CPU and a second GPU then you should probably go for a higher wattage PSU. But if you are sticking with 1 GPU then a 550w is way more than enough.
https://linustechtips.com/topic/549058-enough-power/#findComment-7252359
i want to upgrade my CPU sometime in the future and i will probably upgrade my gpu when it doesn´t preform well in games.. ill aks you guys when the time is right i guess..
https://linustechtips.com/topic/549058-enough-power/#findComment-7252370
Any CPU you could throw in that board would still be fine with a 980 ti and the 550 G2. Adding that and a SECOND GPU could push it over.
A good future upgrade if you ever feel you need it is the EVGA 750w B2, constantly found for $50-$65.
With one GPU it isn't necessary though.
https://linustechtips.com/topic/549058-enough-power/#findComment-7252377
so lets say a i7-4790k and a 980ti it would still be ok?
https://linustechtips.com/topic/549058-enough-power/#findComment-7252425
