Hi guys,
First of all I want to mention that I'm from Australia, so probably have a smaller  range of laptops are compared to your US and Canadian residents.
Anyway, I'm looking for a laptop that's compact enough for me to take to uni (looking at 13" laptops here) and something that I can use to do lighter programming as well as photoshop & illustrator (preferably running both of these at same time).
I was told to look into the xps 15 as the 13" model doesnt have 16gb of ram, and it is 8gb soldered on. A friend also suggested a surface pro 4, but i'm unsure what sort of configuration of specs i'd be looking at for my needs.
I was also suggested a macbook pro retina as the screen is really good for design and the 2016 model won't be coming out anytime soon.
If you guys could give me a couple options, something that is able to do what i need it to that would be awesome :) Also if anyone could mention whether 16gb of ram is really needed for what i do.
I run a i7 4790k and 16gb at home and that seems to work out fine for me.
I'm looking at spending around 2400 aud MAX but i'm a bit flexible and a cheaper solution would be great
Thanks!
https://linustechtips.com/topic/548600-laptop-for-uni-design-work/
3 minutes ago, celixarts said:
Hi guys,
Anyway, I'm looking for a laptop that's compact enough for me to take to uni (looking at 13" laptops here) and something that I can use to do lighter programming as well as photoshop & illustrator.
Thanks!
8 gigs of RAM will work fine for your needs.
My Build: Phoenix
Processor: Intel i7 4770k, Motherboard: Asus Z97-P RAM: Corsair Dominator Platinum 16GB GPU: MSI GTX 1050TI OC Case: Corsair ICUE 4000X, Storage: Samsung 840 EVO 120GB + 500GB + 2TB HDD PSU: Corsair RM750, Cooling: Corsair H100i Capellix,
        If you want to talk to me or give me an answer, please tag me otherwise you'll be talking to thin air ❤️
8 hours ago, celixarts said:
Okay thanks! What laptop do you think would suit my needs i mentioned in original post?
The Dell XPS 13 is a good laptop but if you want a dedicated GPU and a more upgradable laptop you should look at the XPS 15.
My Build: Phoenix
