What is normal temps for 5960x with kraken x41/61
Solved by VerticalDiscussions,
5 minutes ago, Bajantechnician said:-snip-
Yeah theyr totally fine. If your too worried still, maybe you could try to add some extra fans or clean/replace them or even renew the thermal paste and attempt to improve airflow by moving it to a cooler place, but otherwise those temperatures are fine. For reference, my H110I GT with a locked I5 4670, gets about 38Cº at max loads, but that again is fine, since at idles it sits at 24-26Cº. Yours is a 5960X and even overclocked, still manages to get relatively chilly, with the X61. Overclocking further with the X41 may not be as pleasent to look at temperatures, but even so its fine for a single fan all in one.
Sidenote: At idle, a Kraken X61 should get it to 22-25Cº. So at 30Cº with a slight oc, it looks fine.
