What is your intended use for this build? The more details the better. For gaming micecraft, fallout 4, GTA V, Just Cause 3, CSgo & firewartch I would also use the build to stream on twitch
If gaming, what kind of performance are you looking for? (Screen resolution, FPS, game settings)
I would like to be able to play games on medium or high settings with good FPS i.e. playable over 30 FPS
What is your budget (ballpark is okay)? 450 to 470
In what country are you purchasing your parts? I am Living in Ireland but I am Purchasing my parts from Germany
Post a draft of your potential build here (specific parts please). Consider formatting your parts list. Don't ask to be spoonfed a build (read the rules!).
CPU: Intel Core I3 6100 GPU: Gigabyte GTX 950 2GB CASE: Sharkoon VG5-W mit Sichtfenster Midi Tower POWER SUPPLY: corsair 550 watt non modular 80+ HARD DRIVE: 500 GB Seagate HDD laptop (Can i use this hard drive in a desktop?) MOTHER BOARD: ASRock H110M-DGS/D3 Intel H110 So.1151 Dual Channel DDR3 mATX Retail RAM: 8GB G.Skill F3-1333C9S-8GSL DDR3-1333
Provide any additional details you wish below.
sorry for not using PC part picker the website i am using is on PC Part picker but not everything is on it My budget is really strick i intened to upgrade the hard drive later this year. I would like to know if I could stream and play games without crashing and having a good experience?
https://linustechtips.com/topic/548427-need-help-with-new-pc-build/
@BensUniverse
You can build a pc for 450-470 euros, that isn't the problem. It will even have sort of decent graphics at 1080p in most games, even GTA V and other AAA games.
But also streaming?! I don't think you can realistically build a pc with which you can stream and game at the same time (especially the games you're talking about) for 450-470 euros and have an enjoyable experience as well.
2 hours ago, Wouterrinos said:
@BensUniverse
ok thats grand i kinda thought that
Just one more question, do you want your pc to be all new parts? Because if you consider usedparts, you'll maybe be able to get something going.
And now I think of it, do you already have the games you're talking about?(because the aren't dirt cheap)
I have considered it but cant buy pre owned stuff because their is no market for it and i have set a side money for games
Well that's a shame. I don't know the Irish usedparts market that well (obviously), so I'm not able to tell you otherwise, but I had expected there to be atleast some sort of online secondhand market for such stuff or a few pc stores that sell usedparts/used pc's. So that would mean saving up a bit more. For what you're looking for (new), I would say you need about 700 euros at least (would still be a bit cramp), but at 800 you would be totally fine to stream, game and still enjoy it.
This would be a great system to stream and game on and budget and have not just okay-ish quality: http://pcpartpicker.com/p/kgWPMp
For a bit less (about 700 dollars) this is a good one: http://pcpartpicker.com/p/RZTNR
But if you have the time, might as well save up for the 800. (prices will differ quite a bit for you Country, look it up to have a precise number).
For a bit less (about 626.12€) this is a good one: http://pcpartpicker.com/p/RZTNR
their is a market but only pre built machines and their askinng way to much for them! im not personally buying this my parents are so i cant wait i think ill go with this build for know
Buying now is also possible, but make sure you buy some parts which will last you a long time, even if you upgrade. If you go for a 80+ gold 650W psu, you can even run cards like the 390, 980ti and probaply all the next gen cards as well. The same goes for the case: buy a case which isn't to small so you won't have any trouble fitting other stuff when you're upgrading (lookning at pcpartpicker for popular cases can also help). And the last thing you'll use for some time is the HDD/SSD, so buying one which is good quality and right size (SSD min 120gb en HDD min 1TB) will save you a lot of costs when you're upgrading in the future.
