i tryed to overclock my q6600 for 2 days but i cant manualy overclock my cpu the option to change cpu speed stays stuck on auto
the only way i can overclock is via the n.o.s overclocking setup with a overclock setting of 20% overclock results > 2.88ghz at 1.228V stable, temps : under 50 degrees Celsius at full load
system specs :
intel core 2 quad q6600 b3
asus p5k premium wifi-ap black pearl edition
4gb of ram hyperx blu 1066mhz (2 kits of 2 dims)
palit gtx 460 green edition 786mb
cooler master silent pro 620w 80+
https://linustechtips.com/topic/54822-q6600-overclocking-problem/
Dude this is just really old type of question it will be really hard for someone to remember and be able to help you
Better luck if you look on Google or youtube
Sent from my HTC One using Tapatalk 4
| CPU ------ i5 4670k 4.4ghz ------ MOBO ------ MSI Z87 GD65 ------ GPU ------ MSI TF3 7950 OC ------ GPU2 ------ EVGA GTX660 SC ------ RAM ------ G.SKILL Sniper ram 1866 2x4 ------ PSU ------ Corsair AX860 ------ SSD ------ Kingston Hyper X 3K 120GB ------ HDD ------Seagate 1TB ------ CASE ------ Corsair 300r |
https://linustechtips.com/topic/54822-q6600-overclocking-problem/#findComment-761799
