Hiya all,
I have an EVGA PSU. It's a 550W g2 80+ Gold PSU.
It has a cable called a Molex Perif cable and I am unsure where it plugs in. It has a converter that changes it into a fan connector that looks like it goes into a fan header.
Please can I have some assistance as where to connect this cable and if I need to or not?
Cheers, all the best,
Kallum.
Processor: i5-4690k @ 3.5GHz. Mobo: MSI Z97 Krait Edition. RAM: HyperX Fury 16GB @ 1866MHz Dual - Channel. Storage: WD 1TB HDD. 850 EVO 250GB. Sandisk SSD PLUS 240GB. GPU: ASUS STRIX GTX 970 DirectCU II 4GB GDDR5. PSU: EVGA Supernova 550 G2. Case: Phanteks Enthoo Pro M. Monitor: BENQ GW2270H Full HD 21.5". OS: Windows 10 Home 64 bit.
http://uk.pcpartpicker.com/p/rhnhRB
https://linustechtips.com/topic/547836-power-supply-help-please/
pic?
https://linustechtips.com/topic/547836-power-supply-help-please/#findComment-7238581
If you don't need it, don't plug it in. They are mainly used to plug fans into the power supply, however, depending on the motherboard you have, you could have anywhere from 2-6 fan headers. Molex is a dying connector. Manufactures include just incase. Some power supplies still include floppy connectors.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/547836-power-supply-help-please/#findComment-7238582
I currently have 3 fans, 1 exhaust at the back, one on my CPU cooler and one as in intake (oh and 1 in the PSU but that doesn't really count.)
They are all connected to the motherboard via cpu/sys fan headers.
Does this mean that I do not need the molex one?
Cheers.
https://linustechtips.com/topic/547836-power-supply-help-please/#findComment-7238607
Cheers.
Sounds like you don't need the molex connector then. As @deVIZtation said, manufacturers just include it incase it's needed for old stuff.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
https://linustechtips.com/topic/547836-power-supply-help-please/#findComment-7238699
Ok thank you very much.
All of my 3 fans are connected via cpu/sys fan connectors.
Is that ok then?
Cheers.
https://linustechtips.com/topic/547836-power-supply-help-please/#findComment-7238703
Is that ok then?
Cheers.
That's all good. Many mobo's even allow you to change the sys/cpu fan speed in the bios.
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
https://linustechtips.com/topic/547836-power-supply-help-please/#findComment-7238722
Thank you
https://linustechtips.com/topic/547836-power-supply-help-please/#findComment-7238732
