Hello friends, i've had a couple of headaches with this error in the past and i change the power supply for a CX750, however things didn't work, after a while i figure out the look like was a problem with one of USB connectors, i stop using that connect and things worked fine for a couple of months, but yesterday i was playing XCom 2 and the pc shutdown for no reason, first thing i did was take out the power connect wait a little and power the pc again, worked fine and looking thought the Windows logs i found the Kernel Power error, the usb who i thought was the trouble wasn't connect, i did use normally until now, i was playing CoD BO 3 for about 2-3 hours and the pc shutdown, i did everything the i could and couldn't restart my pc, i change the power supply for my old OCZ600w (the one the i change for my CX750 when i thought the was the power supply who was causing the trouble), after turn on again i could look the logs and saw again the Kernel power Error once again.
Things the i did:
Test the mem - OK!
Change the Power Supply - Ok!
No OC - Ok!
Latests Nvidia Drivers - Ok!
I don't think the power supplys are the trouble, since i had problem with both of them and after figure the USB out they were working fine...
My pc specs:
3570K (stock now, previously 4.2ghz)
mobo Z68MAG43-G3
GTX 780 (stock)
16gb Corsair Vengeance
SSD 120 EVO Samsung
PS: OCZ600W // CX750
Any ideias?
https://linustechtips.com/topic/547432-kernel-power-error-41/
A error 41 only means the system didn't turn off right.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/547432-kernel-power-error-41/#findComment-7234404
This error have been a major problem for me since it's happening almost everytime the i'm playing, i change the power supply to my CX750M and didn't turn on everything was connected, swipe my OCZ600W, seems the CX750M is the problem, starting the RMA.
Thanks anyway!
https://linustechtips.com/topic/547432-kernel-power-error-41/#findComment-7234628
