Does anyone know what kind of sleeving I can buy/ where to get it for a headphone cord? I noticed my cat chewed a bit on my headphone cord, and I want to sleeve it with some nice sleeving to make sure their teeth don't get to the wire, plus it'll look nice.
Oh and some heatshrink too pls :q
Link me if you can, thanks :D.
https://linustechtips.com/topic/54713-cable-sleeving/
This should have you covered, it's the best quality sleeving you can buy.
http://en.mdpc-x.com/
https://linustechtips.com/topic/54713-cable-sleeving/#findComment-735239
thx friend :}
https://linustechtips.com/topic/54713-cable-sleeving/#findComment-735248
pexon on the forums sleeved a headphone cable and it looks really nice.
https://linustechtips.com/topic/54713-cable-sleeving/#findComment-735254
im probably just going to put the sleeve over the cable that's already there so it'll be extra thick, one of my cats (idk which) decided to leave like 6 teeth marks in it, so now I must defend the ath-ad 900x
https://linustechtips.com/topic/54713-cable-sleeving/#findComment-735262
how are those headphones? Those are the ones I plan on getting. I don't think it matters if it's extra thick having a cable usually means a cat will attack it.
https://linustechtips.com/topic/54713-cable-sleeving/#findComment-735269
im mainly just using it in hope's they wont be able to sit there and bite through the cable, maybe I can spray it with some kind of something that'll keep them from chewing on it, but I need to figure out something, because im pretty sure I cant send them back and ask for new ones ._.
they're great, I have em paired with a phoebus in my rig, its a little much but they sound amazing so idc lol
https://linustechtips.com/topic/54713-cable-sleeving/#findComment-735283
That would be funny if they would. I have 2 cats so I understand your pain of cords; my desk is sometimes a playground for them. Wasn't planning on getting a $200 soundcard, but after I get them I will probably save up for a fiio e10.
https://linustechtips.com/topic/54713-cable-sleeving/#findComment-735304
they're only like 38 ohm impedance you could probably get like a fiio e6 or something idk how much of a difference you'd notice by spending the extra for the e10, I want to buy one for my ipod but i dont have the $ atm
https://linustechtips.com/topic/54713-cable-sleeving/#findComment-735310
