So i got my hands on this cisco AP (Model Number AIR-AP1242AG-E-K9)
The Problem Im having is deciding if it would be worth getting a POE adapter for it. Does anyone here know if they have good range and performance. Or just general information about them.
All help is very apretitated.
https://linustechtips.com/topic/546929-ap-help-needed/
6 minutes ago, Altecice said:
Its not really worth using it for anything more than messing around with. They only support a/b/g (cap out at about 13.5Mb/s) mostly due to the 10/100 Ethernet uplink.聽
My Internet is 40/40 Mbit/s would this be able to deal with that fine?
https://linustechtips.com/topic/546929-ap-help-needed/#findComment-7229516
