My CPU's quality
Go to solution Solved by Mazeman03,
Just now, Liam Wilson said:
Should I just buy a different CPU and motherboard and have the other components installed onto it?
i mean you can just get a gtx 960 and be good.
Hello, I currently have a HP Pavillion 530, and was wondering what cpu and gpu upgrades I could get. Do I really need a new CPU? As a GPU I was thinking of a http://www.amazon.ca/Gigabyte-GDDR5-Overclocked-Graphics-GV-R938WF2OC-2GD/dp/B00ZGF3ULK/ref=sr_1_2?ie=UTF8&qid=1455321832&sr=8-2&keywords=amd+radeon+r9+380, I have a motherboard in mind and a psu in mind aswell. Please leave your suggestions.
PU: AMD A10-7800 12 Computing Cores(8C + 4C) @ 3.5 GHZ
GPU: Radeon R7 + R7 240 DUAL Graphics DUO
RAM: 8G DDR3 @ ~1100 MHZ
OS: Windows 10 64 BIT
MOTHERBOARD: HP 2B35
ALL AIR COOLED
https://linustechtips.com/topic/546642-my-cpus-quality/
ALL AIR COOLED
what budget ?
What are you going to do with the PC ?
What region?
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/546642-my-cpus-quality/#findComment-7227053
1 minute ago, Liam Wilson said:
say 400$? Game. Canada
you could easily keep the cpu no problem. I would advise getting a new gpu and possibly and ssd. What power supply do you have and what wattage?
https://linustechtips.com/topic/546642-my-cpus-quality/#findComment-7227094
1 minute ago, Mazeman03 said:
but yes you'd need a new CPU if you get that GPU otherwise it will be a bad bottleneck
For that GPU what CPU should I get?, and if I don't upgrade my CPU what GPU should I get to have games like Arma 3 run well(30-40fps on low)
https://linustechtips.com/topic/546642-my-cpus-quality/#findComment-7227098
umm you can maybe get by with a gtx 950 or 960 and for AMD idk a 270x
i heard ther A10 is like a 860k and if it is thoes GPU's should work
1010011010/29A
https://linustechtips.com/topic/546642-my-cpus-quality/#findComment-7227105
http://www.amazon.com/dp/B00K85X23O/?tag=pcpapi-20, I don't understand the whole point of an ssd, ya I mean it's faster but I really don't care about them XD, what gpu do you suggest?
https://linustechtips.com/topic/546642-my-cpus-quality/#findComment-7227113
This
https://ca.pcpartpicker.com/part/asus-video-card-strixgtx960dc2oc4gd5
The a 10 you have is basically an atlon x4 860, which is fine for mid range pc gaming,  and should be fine with the 960.
I usually recommend the 380 over the 960, but using an amd cpu with an amd gpu isn't a great idea,  thanks to the cpu overhead.
https://linustechtips.com/topic/546642-my-cpus-quality/#findComment-7227194
would the motherboard only support APU's?
it all depends on the socket. since your cpu (apu) is a A10 and an A10 is a FM2+ socket that means your motherboard is a FM2+ socket/ so the best you can get is a 860K and thats pretty much the same just your apu has onboard graphics and the 860k does not.
1010011010/29A
https://linustechtips.com/topic/546642-my-cpus-quality/#findComment-7227201
4 minutes ago, Coaxialgamer said:
This
Thinking ahead of time, should I just buy a different CPU and motherboard and have the other components installed onto it?
https://linustechtips.com/topic/546642-my-cpus-quality/#findComment-7227220
Is it really worth it?
https://linustechtips.com/topic/546642-my-cpus-quality/#findComment-7227222
