I am using an acer laptop with i3-5005U and GeForce 920M.
I noticed that Nvidia got an update so I tried updating it but it always fails so I did a manual update.
I downloaded the latest on GeForce website by entering 920M and got the result. Downloaded the latest.
As I try to install I experienced an error. I tried both custom and express install.
Now I dont have drivers for my Nvidia because it always fails. Please help me.
This is the screenshot of the error im getting on both custom and express install.
CPU: Ryzen 7 5800X | MOBO: Gigabyte B550 Vision D | RAM: Crucial Ballistix RGB 32GB 3600MHz | GPU: Gigabyte RTX 3070 Vision D | PSU: Seasonic Focus+ Gold 750W
https://linustechtips.com/topic/546466-need-big-help-pls/
Download ddu (a driver removal tool) and try again
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/546466-need-big-help-pls/#findComment-7225139
use ddu to remove the drivers
then clean install the drivers
and make sure you restart  between each time you install or uninstall some piece of software, a lot of people think they can just do everything without restarting at all
https://linustechtips.com/topic/546466-need-big-help-pls/#findComment-7225151
Thanks! It worked. It seems that the "Clean Install" option on the Nvidia installer is useless. They should remove that crap.
Again thanks a lot.
https://linustechtips.com/topic/546466-need-big-help-pls/#findComment-7225432
Again thanks a lot.
clean install just reinstall the drivers and resets settings
it does not remove the old drivers
thats why you needed to use DDU
https://linustechtips.com/topic/546466-need-big-help-pls/#findComment-7225453
Again thanks a lot.
Not useless, but sometimes it just isn't enough. Glad I could help :)
My rig:
https://linustechtips.com/topic/546466-need-big-help-pls/#findComment-7225485
But you can! ^-^
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/546466-need-big-help-pls/#findComment-7225653
1 minute ago, FruitBasketSilex said:
But you can! ^-^
no, as you can see from this entire topic
https://linustechtips.com/topic/546466-need-big-help-pls/#findComment-7225663
That was a joke, insinuating that I do not restart between installations and uninstallations. Hence the ^-^
https://linustechtips.com/topic/546466-need-big-help-pls/#findComment-7225671
