Sd card slot not working
Go to solution Solved by Lil Chillbil,
check the connector to the motherboard, may have come off.
I already figured it out in the previous post, the power plug came out  :P
I opened the thing up, it came unplugged and was not getting power
weird... cause I didn't move it at all but there was a small earthquake about an hour ago when I wasn't home
#KilledMyWife
LTT's Resident Black Star
I should get an award for still being here at this point
https://linustechtips.com/topic/54602-sd-card-slot-not-working/#findComment-733912
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
https://linustechtips.com/topic/54602-sd-card-slot-not-working/#findComment-733968
#KilledMyWife
https://linustechtips.com/topic/54602-sd-card-slot-not-working/#findComment-734044
