Are Razer laptops paying a lot for the brand instead of performance?
I'm wondering because the Blade Stealth looks nice for the price.
If it is just branding then what is a good 1000-1200 USD alternative?
(I need at least four cores, good battery life, on the lighter side, and I don't want anything above 15 inches in screen size.)
Thanks!
3600X @ stocke | 5600XT TUF OC @ 1850 | 2x16 + 2x8 RAM 3200 HD | 1tb Samsung 970 EVO Plus | Lian Li 205M | TT Toughpower Grand RGB 850 | throwaway b450 asus mobo | BQ cooler
https://linustechtips.com/topic/545987-razer-blade-stealth/
Stealth is dual core, and this one Razer product is actually priced pretty well for being an Ultrabook. I would look elsewhere, though. Something like the MSI GS30 is REALLY good for a great price. There are a few on eBay for good deals. http://www.amazon.com/MSI-GS30-processor-Aluminum-13-3-Inch/dp/B00T7XRP4A/ref=sr_1_2?s=pc&ie=UTF8&qid=1455230838&sr=1-2&keywords=gs30+shadow
https://linustechtips.com/topic/545987-razer-blade-stealth/#findComment-7219698
i think you just pay a premium for just how it looks. the specs are overpriced for the price that they sell at.
"Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning." -Albert Einstein
https://linustechtips.com/topic/545987-razer-blade-stealth/#findComment-7219706
Thanks!
I am also in this predicament, I need a good size small laptop.
however, I have seen some good things like Lenovo Yoga series laptops, those are nice. As well, the Surface Pro 4 and Surface Book are great. There are plenty of articles online.
http://www.laptopmag.com/best-ultrabooks
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/545987-razer-blade-stealth/#findComment-7219708
Thanks for the speedy replies!
I guess I missed that this one was dual-cored...
I have seen the Lenovo laptops. They look like they have great value but I have heard about reliability problems.
The MSI ones look good, but they are absolutely massive.
https://linustechtips.com/topic/545987-razer-blade-stealth/#findComment-7219767
The first one has a quad core and is only slightly heavier, thicker than the Razer. It also has the ability to add an external GPU.
https://linustechtips.com/topic/545987-razer-blade-stealth/#findComment-7219779
The first one is over four times as heavy...
https://linustechtips.com/topic/545987-razer-blade-stealth/#findComment-7219800
Lmfao it doesn't weight 13 lbs it weighs 2.65 (this is from another listing)
Intel® HM87 Chipset
2x M.2 Slots
SATA Slot for 3.5" HDD In Dock
Two 204Pin SODIMM Sockets - (16GB Max) DDR3 1600MHz 64-bit Wide DDRIII Data Channel
4 x Built-in Speakers
1 x Built-in Microphone
S/PDIF Digital Output
2 x Speakers(5W) + Subwoofer (5W) (In Dock)
2-in-1 Card Reader - XC / HC
2 x USB 3.0 Ports
1 x HDMI 1.4
1 x Intel 7260 Wilkins Peak 2 LAN
1 x Microphone
1 x Headphone Out Jack
4 x USB 3.0 Ports (In Dock)
4 Cells - Smart Lithium-Ion Battery Pack
19 V DC, 65W | 100~240 V AC, 50/60 Hz Universal
450W AC Adapter (In Dock)
Size:
12.59" (L) x 8.93" (W) x 0.77" (H) 2.65 lbs
14.34" (L) x 8.00" (W) x 8.09" (H) (Dock) 9.25 lbs
https://linustechtips.com/topic/545987-razer-blade-stealth/#findComment-7219813
Well, if you don't necessarily need a laptop, why not look into small form factor PC's?
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/545987-razer-blade-stealth/#findComment-7219853
" good battery life, on the lighter side "
Ah. Apologies.
https://linustechtips.com/topic/545987-razer-blade-stealth/#findComment-7219883
