My Power Indicator is Too Bright
Solved by MajorSpud,
Just now, Rodniz said:Ive done the same with my girlfriends pc. Remove the front panel, dissassembly the led thingy, put black tape over it and do the whole thing in reverse. A little bit of work, but it will be worth it.
That seems like a good idea. I'll give it a shot.
1 minute ago, Otomaru said:
I did google it, I just didn't understand what I was reading. So I would solder a resistor into the cable? I do have a soldering iron, so this seems like a good idea. Have any recommendations on where to buy the part?
