Hello,
I'm Phani, I'm facing heat issues with my GPU and CPU. I've AMD-FX9370, and SAPPHIRE TOXIC R9 280X. I want any one to help out on liquid cooling system or water cooling system, which can reduce heat and let me do my 3D work. I've done R&D, but I'm not getting any soulution for my card n cpu.Kindly suggest me suitable kits for my PC.
Thank You
https://linustechtips.com/topic/544974-liquid-cooling/
ditto on what are your temps and are you overclocking either? if your not overclocking but you still want water the corsair h60 or h80i would be suitable for the cpu. as for the gpu check http://www.performance-pcs.com/water-blocks so see if there are any blocks for your gpu. i am not aware of any 3rd party aio coolers for gpu's so if there arent any youll be forced into either custom loop cooling or creating an army of fans
Chief of the Red Hands multi-gaming group
https://linustechtips.com/topic/544974-liquid-cooling/#findComment-7209462
