Hello
i have a nzxtcase with
1x 120mm rear (Radiator good)
1x 140-120mm top
2x 140-120mm front(radiator good)
i was wondering if I were better to get a rear aio water cooling that's 120mm or a dual 140mm radiator in the front. Or get an air cooler for my cpu and two front intake 140mm & 120mm rear and 140mm top ??
thanks
any recommendations on fans/aio/cpu air coolers needed thanks
https://linustechtips.com/topic/544738-cooling/
4 hours ago, mrcameron999 said:
Hello
1x 140-120mm top
thanks
It depends what you want but in general a dual AIO would be a great option, if you like air cooling however large air coolers like the NH-D15 are very comparable to the performance of dual AIO's.
https://linustechtips.com/topic/544738-cooling/#findComment-7207039
Hey,
I've got the NZXT s340 with an AIO cooler on the back 2 AF120 on the front and the standard NZXT 120mm case fan on the top.. and I'm loving it looks great and the temps are good.
Now I decided to cheap out on the AIO and went for the Cooler master Seidon 120 v2 I feel if I'd have spent £20-30 more Id have gotten a better max avg temp.  My interim solution is to put a Noctua 3000 industrial fan on i'm hoping this will give me a tiny reduction in max avg temp.
https://linustechtips.com/topic/544738-cooling/#findComment-7208325
7 hours ago, mrcameron999 said:
Is the aio worth the extra money
That's kind of depends on why you like using, large air coolers s put a fair bit of weight on the motherboard where AIO's have it on the heacy rads bolted to the case. Air coolers also have less point of failure since AIO's need a pump and fan in their cooling design. For large dual 140mm coolers they can perform very well espically if you plan to do overclocking however.
https://linustechtips.com/topic/544738-cooling/#findComment-7209704
6 hours ago, Warloghe said:
Hey,
Thanks for your reply's
just to add something to maybe help
https://www.nzxt.com/products/s340-white
this is the case. if i get the AIO what Intake/exhaust should i use
I know what intake/exhaust for the air cooling thanks
https://linustechtips.com/topic/544738-cooling/#findComment-7210113
