PSU Help/Case Help
Solved by Wouterrinos,
8 minutes ago, HeroXLazer said:I'll be running 4790k, ASUS Gryphon Z97 Armor Kit, SLI ASUS STRIX 980 Ti, and some watercooling.
I don't need memory in the loop.
How many watts do I need, what case, and radiator sizes?
first see how many rads you need then how many watt and the case.
one 280/240 rad for each thing you want to cool is the best.
As far as I can see you want to0 cool three things in your loop so 3x 280/240 would be enough.
