hey guys, A the title reads i need help. My laptop is dying and damn it if it isn't time to switch over to a desktop. i would like to buy one from best buy or a store in general but i also think i have the expertise to build it myself if need be. I need a list of components that could easily run star citizen on ultra graphics without a hitch. i also would like it to be able to handle creative cloud and other software as such.
Thanks for your help,
Geekslayer17
https://linustechtips.com/topic/544731-help/
A budget would be helpful.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
https://linustechtips.com/topic/544731-help/#findComment-7205325
Geekslayer17
Budget and location
Intel Core i5-4460 3.2GHz Turbo 3.5GHz | 8GB Kingston DDR3-1333 | MSI Radeon R7 370 OC to 1020mhz | EVGA Supernova NEX B1 750W | GIGABYTE GA-B85-D3H | Inwin Velocity OEM Case | 120mm broken fan
Vancouver, BC | O Canada
https://linustechtips.com/topic/544731-help/#findComment-7205330
Geekslayer17
http://pcpartpicker.com/p/ngBDD3
EDIT:
YOU DO NOT PICK BY BRAND
also this is a low ball one for saving money
https://linustechtips.com/topic/544731-help/#findComment-7205363
Just now, geekslayer17 said:
holy crap that was fast
This is a low ball though I am making another, higher end one
https://linustechtips.com/topic/544731-help/#findComment-7205377
2 minutes ago, geekslayer17 said:
what case do u suggest and how do i add it to the list
click "edit list" then "add case" then choose a case that it tells you are compatible
EDIT:
Also first remove the case
https://linustechtips.com/topic/544731-help/#findComment-7205386
He put the budget of the case as $200 so it is counting that, any mid- large size case should do, go by personal preference, look up some that look nice and then ask if it will work
CPU - Intel I3-6100 Motherboard - MSI Z170-A PRO RAM G.SKILL NT Series 8gb 2400MZ DDR4 GPU - Power Color R9 380X Case - NZXT Source 220 Window Storage - 1TB Western Digital Blue PSU - Corsair CX500 OS - Windows 10 Pro
https://linustechtips.com/topic/544731-help/#findComment-7205403
cool thanks dude and when you finish that other one send it my way
DING http://pcpartpicker.com/p/JcxFcf
$3000 is overkill
https://linustechtips.com/topic/544731-help/#findComment-7205413
Do you want a windowed case?
https://linustechtips.com/topic/544731-help/#findComment-7205416
1 minute ago, geekslayer17 said:
i found a case its the  NZXT Phantom 530 (White) ATX Full Tower Case  and the website says its compatible
so do i have to buy each of these seperately or can i just order them all at once
The website will compare so its multiple websites so you can get the best price. :)
https://linustechtips.com/topic/544731-help/#findComment-7205449
so a couple more questions do i need thermal compound and a resevoir
I dont think you need a resivour so I dont think so and there is pre applied thermal compound
https://linustechtips.com/topic/544731-help/#findComment-7205499
ik its a lot to ask but could you make one with air cooling instead i don't think im ready to handle water cooling
The cheapo or the expensive
https://linustechtips.com/topic/544731-help/#findComment-7205570
https://linustechtips.com/topic/544731-help/#findComment-7205581
