I need help I dont know if my pc will be stable with the GPU that Im upgrading to I have a 430w power supply and i want to upgrade to a gtx 960
I have 2 fans one 120mm and another one 80mm
CPU - amd athlon x4 860k
Mobo - Msi a78m-e35
Ram - DDR3 8gb in a single channel
I use a single monitor.
will this upgrade be ok for me until I get enough money for a new psu or should I just not do it.
https://linustechtips.com/topic/544542-power-supply-help/
What psu do you have? If it's a decent unit then it will be enough.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/544542-power-supply-help/#findComment-7203323
Mobo - Msi a78m-e35
Maybe? Can you give us the exact psu?
https://linustechtips.com/topic/544542-power-supply-help/#findComment-7203328
Mobo - Msi a78m-e35
It'll be fine. However what is the PSU Model?
See my Build here!
Intel 6700k -  Strix GTX 1080Ti - Corsair AX760 - Corsair Dominator 16GB 3000MHz - ASUS Maximus VIII Hero
Seagate Barracuda 1TB -  Samsung 120GB 840 - Samsung 840 EVO 250GB - Corsair H100i - Corsair Air 540 White -
Corsair AF120 - 2x Noctua NF-F12 - 3 x Noctua NF-S12
 Dell S2417DG - Dell UH2515H
https://linustechtips.com/topic/544542-power-supply-help/#findComment-7203329
With that PSU it would be pretty close. It will probably work, but make sure the PSU is cleaned out well and just monitor it for funny noises and stuff
https://linustechtips.com/topic/544542-power-supply-help/#findComment-7203353
Just now, Lakeh said:
ok i got it about a year ago
It should do okaty. My PC never reaches 500W, and I have much more power hungry parts
https://linustechtips.com/topic/544542-power-supply-help/#findComment-7203376
7 minutes ago, Lakeh said:
i have a evga 430w 80+ bronze
thats defiantly fine :)
Builds:
https://linustechtips.com/topic/544542-power-supply-help/#findComment-7203408
