Best Language for Beginner
Go to solution Solved by martward,
I have used several languages, I think Python is the best balance between accessible and usefull. You can do a lot with it, like object oriented programming (so it's a good start if you want to learn Java later on). There are also a lot of packages available for it.
I an looking to start programing but I would like to know the best Language to start with.
(I will eventually want to mod games)
I have an Anet A8 as my project printer and a i3 MK3 for when I want things to work.
I extrude my own filament and haven't saved a penny yet.
My PC:
CPU: Intel i7 8700k
Motherboard: MSI Z370-A Pro
RAM: G.Skill Ripjaws V (2x8GB) DDR4-3200
GPU: GTX 1070 Founders Edition (OC'd)
Storage: 2x 2TB Seagate 5400RPM, 128GB ADATA SSD
Power Supply: EVGA Supernova 750w  B2
Cooling: Noctua NH-D15. 3 Intake Fans, 2 Outtake
Case: Fractal Design Define R6
https://linustechtips.com/topic/544447-best-language-for-beginner/
Just now, ChevbeeHD said:
python i learnt it in school as my first programming language and its super easy to work with
Ok what can I do with python just for example
My PC:
CPU: Intel i7 8700k
Which one looks easy enough to learn?
............Go with that one, then.
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
2 minutes ago, Bgordy2013 said:
Depends on the game that you want to mod. Figure out what language is needed to mod it and learn that. The first language I learned was Java followed by Python. That's because they were the only classes available at my school however.
Ok I might be trying to mod minecraft first
My PC:
CPU: Intel i7 8700k
Java is usually the first object oriented language people try out.
Look up basic programming excercises online e.g. printing fibonacci sequence
 Almost as cool as my temps
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
5 minutes ago, ReesZRB said:
Python, Java then you master the C languages
How long would it take me to learn python?
My PC:
CPU: Intel i7 8700k
Depends on what you want to do
My System:
I want to Learn Javascript but I think i should try python to get a better understanding of how to use Javascript
Is Javascript harder to Learn than C because I was working on learning C as my first language and I understood the basics
My PC:
CPU: Intel i7 8700k
I mean like, what you want to do with Python. The basics are very simple and can be learned in a day or 2. If you want to build complete information retrieval or computer vision systems it'll take you way more time since you will have to figure out all kinds of packages, multithreaded programming and optimalization with respect to computing time and memory efficiency. If you are going to use it as a gateway into other programming languages, I'd say one day for the basics and one or two for object oriented programming (rough estimation).
My System:
Ok thanks :)
My PC:
CPU: Intel i7 8700k
Ok thanks :)
Good luck!
My System:
Python is the easiest language for a beginner, but I'll disagree when people say that it's >best< for beginners. I think that it's better to learn a difficult language first, since doing anything will bring more satisfaction with a more difficult language. My first language was C++, so later learning Python and other languages was a breeze.
This is "hello world" in Python:
print("hello world")
And for a comparison, this is the same thing in C++:
#include <iostream>
using namespace std;
int main() {
  cout << "hello world" << endl;
  return 0;
Remember that Java =/= Javascript.
Python has NOTHING in common with Javascript, so it won't help you much. JavaScript is a fine language and my primary one, you can ask me anything about it :)
#include <iostream>
int main() {
  return 0;
I disagree. Choosing a hard language as your first will require you to spend so much of your time dealing with the tiny idioms and particularities that come with complicated languages while detracting from what you're really trying to accomplish - learning to program. Also, from my experience, beginners are also usually intimidated/annoyed by the complex syntax required by these languages, which leads them to quit earlier on (not to say you cannot start with one of these languages, but from what I've seen more people burn out from them).
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
Well...everything honestly. That's why people use it.
Of course , you can't write an operating system in it and drivers but I assume that wasn't your point.
