2 minutes ago, Wouterrinos said:
don't buy two 980's, just don't
Buy one 980ti
I agree Why would you buy two 980's when you can get 980 ti. BTW what are you getting this pc for?
| Ryzen 9 3950X | EVGA 1200P2 | AMD 5700XT | ASUS Crosshair VIII Hero WiFi | G. Skill 4x16GB 3600Mhz CL16 F4-3600C16D-32GTZN | 2x1TB Samsung 980 Pro | Lian Li O11 Dynamic |
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202258
2 minutes ago, brob said:
What case?
A 2x8GB memory kit would leave room for an upgrade. Actually 2x4GB would likely be more than enough.
Its a Aerocool Strike X GT.  I already bought it so I have that covered.  I plan on running games with a lot of mods so that why I have 16GB
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202260
PCPartPicker part list: http://pcpartpicker.com/p/FJC2Hx
Price breakdown by merchant: http://pcpartpicker.com/p/FJC2Hx/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($395.00 @ Amazon)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($114.99 @ B&H)
Motherboard: MSI Z170A GAMING M7 ATX LGA1151 Motherboard  ($209.99 @ Micro Center)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory  ($42.88 @ OutletPC)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($153.18 @ OutletPC)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($87.44 @ Amazon)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card (2-Way SLI)  ($649.99 @ B&H)
Case: Fractal Design Define S w/Window ATX Mid Tower Case  ($89.99 @ SuperBiiz)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($119.99 @ Amazon)
Total: $2513.44
Generated by PCPartPicker 2016-02-09 12:29 EST-0500
CPU: Intel I5 4690K | GPU: Asus R9 280x | PSU: Evga 600w | RAM:8GB DDR3 | HDD: WD 1TB | HDD: WD 500GB | SSD: Sandisk 120GB
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202319
7 minutes ago, The Bar said:
I'm kind of a fps hoard so two 980 out perform one 980ti
They are just a huge waste of money though. You might as well get a Titan X. Even though many of the people will tell you that a 980Ti is about the same except for the number of cuda cores. Even though you are a fps hoard you dont need this extreme of a build for gaming. I could maybe see a build like this for video editing and stuff but the 980s are just not needed.
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202339
Found a great deal on a 4k IPS 5ms FreeSync monitor, so I went 390x crossfire instead of 980 Ti SLI. Saved some money too.
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($244.99 @ SuperBiiz)
Motherboard: Asus Z87-Pro ATX LGA1150 Motherboard  ($76.99 @ NCIX US)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($32.99 @ Amazon)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($153.28 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($65.99 @ SuperBiiz)
Video Card: XFX Radeon R9 390X 8GB Video Card (2-Way CrossFire)  ($373.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Micro Center)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ Amazon)
Monitor: LG 27MU67 60Hz 27.0" Monitor  ($517.74 @ Amazon)
Keyboard: Cooler Master Storm QuickFire Rapid Wired Gaming Keyboard  ($69.99 @ Amazon)
Mouse: Logitech G502 Wired Optical Mouse  ($49.99 @ Best Buy)
Headphones: Sennheiser HD 598 Headphones  ($144.98 @ Amazon)
Total: $2229.88
Generated by PCPartPicker 2016-02-09 12:32 EST-0500
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202343
Give me a few minutes and I will build you a build. What are you using this build for?
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202346
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($249.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard  ($139.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($74.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB Superclocked ACX 2.0+ Video Card  ($619.99 @ Amazon)
Power Supply: EVGA SuperNOVA P2 850W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($138.74 @ Amazon)
Case Fan: Corsair Air Series AF120 Red 52.2 CFM 120mm  Fan  ($12.49 @ OutletPC)
Case Fan: Corsair Air Series AF140 Red 66.4 CFM 140mm  Fan  ($14.55 @ OutletPC)
Monitor: Asus VN289QR 60Hz 28.0" Monitor  ($150.98 @ Newegg)
Monitor: Asus PG279Q ROG Swift 165Hz 27.0" Monitor  ($799.99 @ Micro Center)
Keyboard: Corsair STRAFE Wired Gaming Keyboard  ($99.99 @ Amazon)
Mouse: Corsair Raptor M45 Wired Optical Mouse  ($59.88 @ OutletPC)
Total: $2548.28
Generated by PCPartPicker 2016-02-09 12:35 EST-0500
don't get 4x4gb ram, theres no quad channel on Skylake.
Added a 980ti, swapped the PSU, 1000w is overkill (I know check my sig lol) and buy windows from G2A etc
With the money saved there and the 1 less 980 I was able to add in the new RoG Swift IPS Gsync monitor
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202375
How about this... IPS 23" with the IPS ROG Swift (144hz gsync 1440) a 500GB M.2 drive, a 980ti, a 750W EVGA P2, (it's enough for sli 980 Ti's with overclocks) and an extra TB of storage..
Get windows on reddit microsoftsoftwareswap for $20
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($249.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler  ($25.88 @ OutletPC)
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard  ($154.99 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($67.99 @ Newegg)
Storage: Samsung 850 EVO 500GB M.2-2280 Solid State Drive  ($152.99 @ Micro Center)
Video Card: EVGA GeForce GTX 980 Ti 6GB FTW ACX 2.0+ Video Card  ($637.96 @ Amazon)
Power Supply: EVGA SuperNOVA P2 750W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($89.99 @ Newegg)
Monitor: LG 23MP57HQ-P 60Hz 23.0" Monitor  ($120.98 @ Newegg)
Total: $2516.63
Generated by PCPartPicker 2016-02-09 12:34 EST-0500
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202379
Actually my laptop is about to die give me a bit if someone else on here doesnt do it for me.
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202385
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($398.98 @ B&H)
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($63.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive  ($298.99 @ Newegg)
Case: Aerocool Strike-X GT-Bk ATX Mid Tower Case  (Purchased For $0.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($15.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($88.00 @ Amazon)
Monitor: Acer G257HU smidpx 60Hz 25.0" Monitor  ($259.99 @ B&H)
Monitor: Asus VN289QR 60Hz 28.0" Monitor  ($180.98 @ Newegg)
Total: $2486.70
Generated by PCPartPicker 2016-02-09 12:52 EST-0500
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202498
Total: $2486.70
Will that one graphics card be able to run both of those monitors?
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202531
Any of these builds will be great for gaming. No need to spend more money than you have to.
https://linustechtips.com/topic/544441-pc-build-for-around-2500/#findComment-7202625
