so I'm building a pc and have a Intel® Core™ i7-6700K 4.00GHZ 8MB Intel Smart Cache LGA1151 (Skylake) cpu I plan on over clocking it but am not sure what cooling would keep it cool is the Cooler Master Hyper 212 EVO CPU Cooler a good enough cooler to go with instead of a Corsair Hydro Series H110i GT 280mm Liquid CPU Cooling System w/ Copper Cold for cheaper cause if I can save money and get good cooling id like to
https://linustechtips.com/topic/544164-on-a-air-cooler/
How much do you want to overclock it? If you're just going to do a mild-slightly aggressive overclock, go with the Hyper 212. If you plan on pushing that chip as far as it can possibly go, then go for the H110i GT.
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
https://linustechtips.com/topic/544164-on-a-air-cooler/#findComment-7199228
Stock cooler is a good choice for i3 CPUs at best, 212 evo is a good choice for mild overclocks, liquid cooling is good for pretty good overclocks, @Lays is good for extreme overclocks.
https://linustechtips.com/topic/544164-on-a-air-cooler/#findComment-7199243
1 minute ago, ChrisLucero said:
I plan on just a small amount of overclocking seeing its my first build and first time over clocking
Go for the 212 evo, by far. Most beginners really do not need anything more than a 212 evo.
id also like something maintenance free and worry free for the most part so I don't have to worry about it at all
Good, because there is not a whole lot that can go wrong with a rotating fan and a piece of metal
https://linustechtips.com/topic/544164-on-a-air-cooler/#findComment-7199302
id hope not if there is I think we may have a problem
https://linustechtips.com/topic/544164-on-a-air-cooler/#findComment-7199329
If you feel like going for higher OC later, you could go for bigger air cooler. Something like 140mm single towers from Noctua, beQuiet! and Cryorig should do fine.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/544164-on-a-air-cooler/#findComment-7200156
