Will steam ban me for using a VPN?
Azade12
So im traveling to foreign countries and i used a friends credit card to buy a steam gift card online. Little did i know, steam changed my currency to something thats not familiar to me. Is it ok to use a vpn and connect to the US then use my US credit card to purchase a game to reset the currency back? Thanks!
RYZEN 5800X
ASUS B550M (WIFI)
GTX 1060 6G
3200 MHZ RAM
RM650 PSU
256G SATA SSD
1TB NVM.E SSD
3TB 5400 WD HDD
16 hours ago, gFrenken97 said:
No, I use a VPN at school because they block access to Steam
im talking about purchasing a game, not playing one.
RYZEN 5800X
ASUS B550M (WIFI)
GTX 1060 6G
3200 MHZ RAM
RM650 PSU
256G SATA SSD
1TB NVM.E SSD
3TB 5400 WD HDD
If it was some other company, I'd say go for it and prove that you're really from US afterwards if necessary. But Steam is notorious for bad CS. I wouldn't risk it. Have your friend buy it in US and gift it to you or something.
for example youre on vacation, on another continent and you have your laptop with you. theres a new game coming out and you want to play it, so you buy it on steam. do you think theyre gonna ban you because of that? i dont think so...
IF YOU WANT ME TO REPLY TO YOU, QUOTE MY POST.
Fire Strike Score
5820K @ 4.8GHZ - 1.25v / Uncore @ 4.5GHZ - 1.2v / 3000MHZ G.skill 32GB Quad Channel / Asus Rampage V Extreme / 950 Pro Nvme / Sound Blaster ZxR  / 980 TI / Windows 7
I think so? I think the general rule of thumb if it costs more to buy in your country of origin it's OK.
If you used a vpn to buy something for a cheaper price eg Russia I think that is when they start getting pissy. I'm not really sure though
Like E-Sports? Check out the E-Sports forum for competitive click click pew pew
Like Anime? Check out Heaven Society the forums local Anime club
I was only living because it was too much trouble to die.
R9 7950x | RTX4090
Isn't it the same price for each game no matter the currency? I often travel between the UK, France and Canada and when I converted the prices of games to £s from either Canadian Dollars or Euros I always found it was the same price as the British store... of course this may not be the same for all currencies.
Steam isn't very clear and concise about its policies and such, so I wouldn't bother risking the potential headaches, however unlikely they may be. If you want a definitive answer, then all I can say is: "Most likely not."
I think its ok. Im just going to buy a cheap game like serious sam HD
RYZEN 5800X
ASUS B550M (WIFI)
GTX 1060 6G
3200 MHZ RAM
RM650 PSU
256G SATA SSD
1TB NVM.E SSD
3TB 5400 WD HDD
Probably. It's happened before.
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
Its forbidden. But the worse could happen is a warning. They will not ban you right away.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
