so im looking for mouse sub 50$ ish and im looking at the logitech g402 and the steelseries sensei raw ps: i live in canada
Mouse: Logitech g402 <3
Keyboard: Some Tenkeyless with blue kalih switches
Headphones: Logitech g430
Monitor: HP w2207h (1680 x 1050 @ 60hz)
PC Specs:CPU(AMD A8 6500 @3.5ghz), Mobo ( ASUS A68HM-E  FM2+), 1x1600mhz 4gb stick of ram, Random grey PSU, 920gb ssd
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
Laptop:Toshiba satelite with 8gb of ram a 480gb ssd and a mobile 2nd gen I3
https://linustechtips.com/topic/542965-need-some-help/
I'd spend a bit more to get a better sensor. The ...
I just looked up what a mouse sporting an ADNS 3310 would cost ... I feel sorry for all canadians ...
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/542965-need-some-help/#findComment-7183542
2 hours ago, Droidbot said:
OP, the Steelseries Rival 100 is $55CAD on Steelseries.com (you could try somewhere else)
It's a great mouse compared to the Sensei Raw, which has a crapton of acceleration.
oh i heard the rival is terrible because you can't lift it up much to the right up or left and i have a small space for my mice so i would like the acceleration
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
https://linustechtips.com/topic/542965-need-some-help/#findComment-7184035
what games do you play generally? like mobas, fps, etc?
idk
https://linustechtips.com/topic/542965-need-some-help/#findComment-7185906
typically fps games
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
https://linustechtips.com/topic/542965-need-some-help/#findComment-7196206
