Hello!
I want to build myself a pc with the 6700K, and i don´t really know which motherboard to buy. I have thought about the Asus z170 Pro Gaming because it is not too expensive and it has some nice features like USB 3.1 and good audio.
Please tell me if im right or if there is a better option for me.
Thank You!
https://linustechtips.com/topic/542517-z170-help/
asus z170-a
https://linustechtips.com/topic/542517-z170-help/#findComment-7179246
8 minutes ago, mcfloxxx said:
Hello!
Thank You!
thats a good mobo.
if you want another option then the Asus Z170-A
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/542517-z170-help/#findComment-7179273
9 minutes ago, mcfloxxx said:
what´s the diffrence
cheaper, different looks, less "gaming" features which are unecessary
https://linustechtips.com/topic/542517-z170-help/#findComment-7179357
