Audio hum and beeping...
So a few days ago I plugged my Sony MDR-1A headphones into the front audio out and got a LOT of hum and beeping but when I plug the headphones into the back of my desktop I get perfect audio. I am wondering what's wrong?
I want to use my front audio because it's around 50cm away which means I don't have to use an extension chord :)
https://linustechtips.com/topic/542438-audio-hum-and-beeping/
probably something wrong with the front audio and check nothing is actually inside of the jack
https://linustechtips.com/topic/542438-audio-hum-and-beeping/#findComment-7178505
its called EMI
thats what you get when you cross the front panel audio cables over a bunch of power cables behind your motherboard
https://linustechtips.com/topic/542438-audio-hum-and-beeping/#findComment-7178532
Just now, Enderman said:
its called EMI
Oh! So maybe just try to run the audio cable away from all the other cables and see if it works then?
https://linustechtips.com/topic/542438-audio-hum-and-beeping/#findComment-7178538
it will reduce it, but it will never be gone since it still crosses over traces on the PCB
the best solution is to use an external DAC or plug a 3.5mm extension into the back of your PC and just plug into that
https://linustechtips.com/topic/542438-audio-hum-and-beeping/#findComment-7178577
