Internal Network Speed Question
Hi Guys,
Now I have my new router up and running I thought it be best to back-up a shed load of data to an off-site HDD. So, not really a question about individual application as I see this question being generally network wide. Almost regardless of network connection speed, I seem to only be able to hit a maximum transfer rate of 15-20 mb/s depending on which device despite being connected at nearly a giga-bit mbps.
Not that I'm complaining because for an internal home consumer network, I still see this as being above average and it works very well but it got me wondering...
Example:
Currently I have an external USB 3.0 Seagate drive using SATA > USB (standard cable) plugged in to the USB 3.0 port on the TP-Link Archer C9 Router, which is then copying back and forth to my slave / server PC which is connected via Wifi at around 877 Mbps. Which on paper just based on those facts should give around a 100-110 MB/Sec transfer rate, as you can see, im hitting some 15% of that.
The only thing that I can see actually being the bottle neck would actually be the router CPU, but that is just a guess. (The actual PC Hard-drive we are copying too / from is a WD Red Drive, not that it matters as Iv tried it on the SSD 840 Evo also).
What do you think?
https://linustechtips.com/topic/542329-internal-network-speed-question/
I understand that, however, that would suggest that distance / interference / connection speed would play a large factor which in this case, it does not... not a huge affect anyways. Even if I'm sat right next to the router (which I am right now), the speeds remain the same. Which makes me think that something else is the bottle neck apart from the wireless connection itself.
I think the bottleneck is the router itself, between the WLAN and USB 3.0 interface. What partitioning are you using on the flash drive? As per here
TP-LINK Archer C9 Linksys WRT1900AC Linksys EA6900 NETGEAR R7000 ASUS RT-AC68U
Processor Broadcom BCM4709A Marvell MV78230 Broadcom BCM4708A Broadcom BCM4709A Broadcom BCM4708A
FAT32 Write (MBytes/s) 22.8 28.7 14.5 24.8 11.8
FAT32 Read (MBytes/s) 28.7 31.0 21.0 27.8 24.0
NTFS Write (MBytes/s) 17.2 30.1 17.2 27.9 23.7
NTFS Read (MBytes/s) 23.9 30.8 21.2 27.9 24.2
With NTFS you will see Read/Write of 23.9MB and 17.2MB. Also, what HD do you have in the slave PC? You might be further bottled necked by the OS. I would try to isolate the greatest bottleneck by testing different transfer rates one at a time. Like WAN > USB and USB > LAN and LAN > LAN. Newer routers have separate CPU just for the USB interface to increase speeds. C9 is a great router, just USB transfer speeds is one of it's weaknesses.
That makes PERFECT sense then. Many thanks for that dude, clearly identifies my bottle neck. Applicable to me NTFS Write Speed 17.5 MB/S Max (I have seen it go this high a couple of times but settles as per above). At least now I know. Its not a function to be used all that often by me so im not that bothered by it but wanted to understand it further.
