Charger Question Regarding Voltage
Go to solution Solved by SeanAngelo,
19 minutes ago, flowalex said:
First of all sorry if this is in the wrong spot, or there is a post like this already, I searched and couldn't find one already made.  My question is that my laptops charger says 100-240V ~1.6A50-60HZ and I am wondering if I get a plug for the UK that goes into my charger will it be fine (I am from the US and never traveled with it out of North America)?
Thank you in advance
yeah it will be fine.
UK deals with 230V and 50Hz i think so you should be ok.
I have products that came from Philippines and it works fine :)
https://linustechtips.com/topic/542229-charger-question-regarding-voltage/
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
