Need advice constructing a loop
Working with C++, I'm struggling to create a loop (just learning them) and am just trying to accomplish something simple.
Goal: Program will ask a question (only certain inputs are acceptable) and if the user doesn't answer the question correctly it will re ask the question but in a different way. For example, instead of just asking "Please enter your weight:", if they didn't enter a valid weight (like 5000, -7, etc.) it would ask something like "Invalid input, please try again". The sequence would keep repeating until until they user finally entered a valid input.
For this example, I figured a weight between 1 and 500 was reasonable. This code works, except it just repeats over and over with the same question if not true. Ultimately it servers the purpose, but I want the program to ask a DIFFERENT question if user input is invalid as described above. I'm familiar with if / else statements but couldn't figure out a way to make it work, however I'm not familiar with "else if" statements.
I could really use some help, thanks.
while (weight < 1 || weight > 500)
    cout << "Please enter your weight: " << endl;
    cin >> weight;
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/542170-need-advice-constructing-a-loop/
i think you want the weight to be between 1 and 500, right?
then you need to do AND not OR, (IIRC and is &&)  and you need weight>1 and weight<500
you have your ><><  the wrong way
then you need to do AND not OR, and you need weight>1 and weight<500
I'm not sure what you mean. The code works, only a valid number between 1 and 500 is acceptable, that code works fine. But if you enter an invalid number it just repeats and asks the question, until the condition is true. If the input is invalid, I want it to ask a different question, as I described above.
then you just need to add an if statement after the cin that checks if the input was between 1 and 500 then say something, then an else statement that asks a different question
unless you want the new question to replace the weight question, then thats more complicated because you need to make the question a variable string which gets modified in the else statement
sort of like this:
(my c++ hasnt been used in a long time)
x="What is your weight?";
loop starts here
    cout<<x<<endl;
    cin>>weight;
    if (weight>1 && weight<500)
        cout<<"your weight is between 1 and 500 lol"<<endl;
    else
        x="how old are you?";
int weight, height, age;
bool isWeightValid = false, isHeightValid = false, isAgeValid = false;
do
	cout << "What's your weight? (1 - 500)";
	cin >> weight;
	if (weight > 1 && weight < 500)
        isWeightValid = true;
    cout << "what's your height? (1 - 500)";
    cin >> height;
	if (height > 1 && height < 500)
        isHeightValid = true;
    cout << "what's your age? (1 - 500)";
    cin >> age;
	if (age > 1 && age < 500)
        isAgeValid = true;
    cout << "Entered weight is " << ( (isWeightValid) ? "valid" : "not valid" );
    cout << "Entered height is " << ( (isHeightValid) ? "valid" : "not valid" );
    cout << "Entered age is " << ( (isAgeValid) ? "valid" : "not valid" );
}while( !isWeightValid || !isHeightValid || !isAgeValid );
If there's other fields, test if that code works. Been a long time I've coded in c++.
