PCIE slot help
Go to solution Solved by Beeeyeee,
yeah you have to use an ethernet cord to connect to the internet and update the wireless card's drivers.
I am trying to install my Gigabyte GC-WB867D-I wifi card onto my MSI Z170A PC MATE motherboard.
The card is not working, and I am wondering if I am doing anything wrong.
The bluetooth function on the WIFI card is working fine, but it is controlled through a USB connection.
I also have a GeForce 210 GPU installed for my multi monitor setup.
I am wondering what I may be doing wrong/what do I need to do to fix it?
https://linustechtips.com/topic/541801-pcie-slot-help/
make sure you have the wifi drivers installed
Ultimate XP gaming system build log coming soon!  Q8200 // 8GB DDR2 // Asus P5E Deluxe X48 // Asus 4870 DARK KNIGHT X-Fire // Supreme FX sound // BFG Ageia PhysX PCI Co-Processor // AX 860x with Silverstone extensions
https://linustechtips.com/topic/541801-pcie-slot-help/#findComment-7172377
