3 minutes ago, Stuff_ said:
My PSU is just a black Evga, but I would love to get white cables to match my white build. Or maybe white and black alternating sleeved cables. Where is a good place to look? This PC will only have, at most, 2 drives.
Any help would be appreciated.
CableMod. They have sleeved cables for almost anything you'd like. Just click on the general PSU model that you have and it will show you compatible cables for your PSU.
https://cablemod.com/products/
https://linustechtips.com/topic/541723-sleeved-cables/#findComment-7171623
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/541723-sleeved-cables/#findComment-7171641
I found one for the G2 EVGA PSU, but the store that is listed for the US doesn't have them in stock. Bleh.
http://www.performance-pcs.com/cablemod-e-series-g2-p2-cable-kit-black-white.html
https://linustechtips.com/topic/541723-sleeved-cables/#findComment-7171646
Either get on the e-mail notice list, or shoot them an e-mail when they will get more in stock.
https://linustechtips.com/topic/541723-sleeved-cables/#findComment-7171661
Well, I found these:
http://www.performance-pcs.com/cablemod-e-series-g2-p2-basic-cable-kit-black-white.html
So, that is just the necessary ones for power, and for at most 1 GPU?
I could add some SATA cables for a couple bucks more, which seems fine for what I need.
https://linustechtips.com/topic/541723-sleeved-cables/#findComment-7171696
