2 minutes ago, pckid said:
There is a sound coming from the inside of my pc and it sounds like a grinding noise. I think it is coming from my hard drive.
Usually a chirping (or grinding maybe) sound from your HDD means your HDD is going bad.
I suggest that you backup your data.
I believe there's a software out there to check your drive's health. I think it's called SMART or something like that.
CPU: Intel i5-4590 | Motherboard: Asus H97M-E | GPU: Sapphire Nitro R9 390 | RAM: 2x4Gb Kingston HyperX Fury Black | SSD: Sandisk Plus 240Gb HDD: Seagate 250Gb  | PSU: Seasonic G650 80+ Gold | Case: NZXT S340
I am who I am.
https://linustechtips.com/topic/540721-sound-coming-from-pc/#findComment-7160775
Open your case and listen around the case and determine where it is coming from (VERY IMPORTANT). You could try to touch the hard drive and see if it is vibrating significantly (All HDD's vibrate a bit, so a small amount is okay). If it does indeed seem to be coming from the HDD, i'd backup your data ASAP.
If it's a Seagate HDD you can use http://www.seagate.com/ca/en/support/downloads/seatools/ to scan the drive to see if it has bad health. For other brands you can use http://www.passmark.com/products/diskcheckup.htm
widget.png?style=banner2
PC: 9800X3D, 96GB Trident Z5 6200 CL28, 5090 FE, 3.84TB CM7
NAS: Xeon W-2195, 256GB ECC, 180TB Storage, 1660 Ti, TrueNAS Scale
https://linustechtips.com/topic/540721-sound-coming-from-pc/#findComment-7160782
Smart said I had a problem with my hard drive over a year ago and now that hard drive is 6 years old so I think it is time to upgrade to an ssd anyways.
https://linustechtips.com/topic/540721-sound-coming-from-pc/#findComment-7160783
If you have the budget then go. It will be a great upgrade. :)
I am who I am.
https://linustechtips.com/topic/540721-sound-coming-from-pc/#findComment-7160800
I probably will
My first hard drive that is older is vibrating a bit more than my newer hard drive and it was making a grinding sound.
https://linustechtips.com/topic/540721-sound-coming-from-pc/#findComment-7160844
Just now, pckid said:
I probably will
If you have the space transfer the data from the old hdd to the new one.
https://linustechtips.com/topic/540721-sound-coming-from-pc/#findComment-7160852
