the 9mm is likely caused by the shrinkage of whatever material you are using. Its always a good idea to take thermal expansion into account when making a model to 3d print. This is especially true when dealing with abs. The extra 1mm of height could easily be from over extrusion.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
