Hello,
I am thinking about building my first pc. My budget is $850 Dollars and I want something that can play games such as Just Cause 3 at 1080p High Settings or Normal. Here is my current thoughts:
(Sorry for bad english, I'm brazilian)
Edited by Barros
https://linustechtips.com/topic/540467-my-first-build/
2 minutes ago, Rob200088 said:
Nice list dude, for the graphics card you may want to consider a nvidia gtx 960 ssc or ftw edition. It cant play nice 1080p at 60 fps and its a bit cheaper. Just a tips :)
390 is a much stronger card, the build actually looks decent
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.89 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.89 @ OutletPC)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory  ($69.99 @ Amazon)
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive  ($69.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($283.98 @ Newegg)
Case: Corsair Carbide Series 88R MicroATX Mid Tower Case  ($38.99 @ Newegg)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ NCIX US)
Total: $835.51
Generated by PCPartPicker 2016-02-03 13:36 EST-0500
that's how I would go, but your build is decent
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/540467-my-first-build/#findComment-7157992
12 minutes ago, Barros said:
Hello,
go for it. Looks like a pretty good build that should definitely be able to push out high settings for Just Cause. Like @Nacho Marco Segui said, you might want to go for a different cooler. Ive heard great things from the Saphire and Powercolor versions of the r9 390.
https://linustechtips.com/topic/540467-my-first-build/#findComment-7158021
Total: $835.51
Change the SSD, very slow read and write speeds.
https://linustechtips.com/topic/540467-my-first-build/#findComment-7158022
I actually meant to change that when I worked out I could get the 390 for less $$$ but forgot lol
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.89 @ OutletPC)
Total: $850.51
Generated by PCPartPicker 2016-02-03 13:45 EST-0500
Ryzen Ram Guide
https://linustechtips.com/topic/540467-my-first-build/#findComment-7158083
Total: $850.51
Thanks man! Big help. Will change to this! :)
https://linustechtips.com/topic/540467-my-first-build/#findComment-7159121
