Ridska here,
I am planning on building a multimedia rig for the Living room for my family's 4k TV.
I was thinking that it should have some sort of speaker system but here is where i need your help.
I have no idea what parts go into a multimedia machine. This is why I'm making this post , I am aiming to get a good idea or good generalisation of what parts go into a multimedia rig.
budget ? Well like i said , I have no idea what goes into a multimedia rig too ill see about that later.
Thanks and stay groove :D.
(⌐■_■)
https://linustechtips.com/topic/540423-multimedia-build-help/
Simple stuff, get a g3258 for your CPU needs, and get a gt 710 for 4K output, then maybe 4gb of ram but might as well get 8gb since its like 30 bucks these days. if you want to beef it up a little, i would recommend an i3 and maybe a 750
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/540423-multimedia-build-help/#findComment-7157400
Thats the hardware stuff , But i want to manage my wifi as well and a good sound system.
Sound card maybe ? out-ternal.
(⌐■_■)
https://linustechtips.com/topic/540423-multimedia-build-help/#findComment-7157435
