you could go with what @FoxxyRin said, or if you already have the RGB strip with the controller, what you would need to do, is find a molex male connector, find the 12v and the ground cable, the 12v one is usually yellow colored and the ground is black, and you'll need to cut the 12v Power cable that came with the RGB strip, and connect positive with the 12v yellow cable, and the ground to the ground cable.
after that you'll need to install the white box some where so you can easily use the IR controller. and then just hook everything up and you should be good
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/540391-rgb-light-strips/#findComment-7157173
23 minutes ago, FoxxyRin said:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811980001
That should have everything you need, and it's all pretty simple to set up. :)
does it say how to install it on manual or something?
https://linustechtips.com/topic/540391-rgb-light-strips/#findComment-7157196
it should be straight forward, just find where you want to put the LED strips, and connect the two with their connectors at each end, and find where to put the power box that has the receiver for the controller.
https://linustechtips.com/topic/540391-rgb-light-strips/#findComment-7157210
