questions about USB bootable
45 minutes ago, Zethlon said:Different codes, dont they cost money?
1 hour ago, Zethlon said:Okay, so im buying windows 10 for my brothers pc, and later mine. and im going to install it on a bootable USB since that seems like the way to go. but i have some questions for this.
1. will i be able to use it multiple times?
if you download a new game by paying for it and burning it to a dvd, you can now install that game on any system, but you can only activate it once for one PC, you can ofcourse install it in your friends PC, but he could never play it without another code for that installation, so you'd have to buy a new copy to get the code
this is the same, you can make a bootable windows USB and install it on your PC and activate it, but you can also install it on another PC, but you can't use the same code for activation you need a new code.
hence i i answered your question, "will i be able to use it mutiple times" - yes on your PC you can install it and use the code as many times, but if you install it on an another PC, you need a new code to activate it.
