Hi !
I've selected some components for my build, this PC is going to be mainly used for video editing and gaming ( I am not going to overclock).
I'm not sure if my components are suitable for this type of build, I would appreciate it if s/o could help me with it.
My main issues are on the motherboard and the psu. What would you change ? Do i need to spend 10 extra bucks on getting a modular psu ?
 Thank you!
Intel Core i7-4790 3.6Ghz Box
Gigabyte H97-HD3
Cooler Master Hyper TX3 EVO CPU Cooler
G.Skill Ripjaws X DDR3 1600 PC3-12800 16GB 2x8GB CL9
Sandisk SSD Plus 120GB SATA3
Seagate Barracuda 7200.14 1TB SATA3
NZXT S340 USB 3.0
Corsair VS650 650W VS Series 80 Plus  or  Aerocool Strike-X 600W Modular
Gigabyte GeForce GTX 970 Gaming G1 WindForce OC 4GB GDDR5
https://linustechtips.com/topic/540356-help-build-pc-1000-bucks/
Something like this is what i would recommend.
CPU: Intel Core i7-4790 3.6GHz Quad-Core Processor  ($289.99 @ SuperBiiz)
CPU Cooler: Cooler Master GeminII M4 58.4 CFM Sleeve Bearing CPU Cooler  ($27.99 @ Newegg)
Motherboard: MSI B85-G43 GAMING ATX LGA1150 Motherboard  ($93.98 @ OutletPC)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2133 Memory  ($72.99 @ NCIX US)
Storage: OCZ Trion 100 120GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  ($297.99 @ NCIX US)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Micro Center)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ NCIX US)
Total: $1007.80
Generated by PCPartPicker 2016-02-03 10:43 EST-0500
https://linustechtips.com/topic/540356-help-build-pc-1000-bucks/#findComment-7156831
It may still be worth it to get a K cpu if you won't overclock as they also have higher stock frequencies.
Modular PSUs are mainly for your own building comfort and looks, if you don't care there aren't really any disadvantages (if the rest of the PSU is just as good).
Depending on the price you may want to get a R9 390 instead of a 970, they tend to be faster for around the same price. They are also significantly better at rendering if the program you use supports opencl.
sudo chmod -R 000 /*
https://linustechtips.com/topic/540356-help-build-pc-1000-bucks/#findComment-7156833
A bit more expensive but totally worth it IMHO.
PCPartPicker part list: http://pcpartpicker.com/p/LgGYnQ
Price breakdown by merchant: http://pcpartpicker.com/p/LgGYnQ/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($329.99 @ SuperBiiz)
Video Card: MSI Radeon R9 390 8GB Video Card  ($319.99 @ Newegg)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ Newegg)
Total: $1044.80
Generated by PCPartPicker 2016-02-03 10:49 EST-0500
https://linustechtips.com/topic/540356-help-build-pc-1000-bucks/#findComment-7156871
i5 instead of an i7 but with a cool looking cpu watercooler
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($254.89 @ OutletPC)
CPU Cooler: Deepcool CAPTAIN 240 91.1 CFM Liquid CPU Cooler  ($69.99 @ Newegg)
Motherboard: MSI Z170A PC MATE ATX LGA1151 Motherboard  ($102.09 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($67.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($297.49 @ Newegg)
Total: $992.31
Generated by PCPartPicker 2016-02-03 11:08 EST-0500
CPU: AMD FX-6100 3.3GHz 6-Core OEM/Tray Processor + Antec Kuhler H2O 620 Liquid CPU Cooler
Motherboard: Asus Sabertooth 990FX ATX AM3+ Motherboard Memory: G.Skill Ripjaws X Series 16GB (4 x 4GB) DDR3-1866 Memory
Storage: Kingston HyperX 3K 120GB 2.5" Solid State Drive + Western Digital Caviar Green 500GB 3.5" 5400RPM Internal Hard Drive & Seagate Barracuda 750GB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI GeForce GTX 960 2GB Video Card Case: Rosewill THOR V2 ATX Full Tower Case + Thermaltake TR2 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter Monitor: Asus VK278Q 27.0" Monitor
Peripherals: Razer DeathStalker Wired Gaming Keyboard + Razer Abyssus Wired Optical Mouse Headphones: Bose SIE2i Orange Earbud Headphones + Mic: Kaxidy Stereo MIC
https://linustechtips.com/topic/540356-help-build-pc-1000-bucks/#findComment-7156969
3 hours ago, J03Y said:
Hi !
What budget, what country, what's your display set up, how important is gaming vs video editing?
in any case you'd want a Xeon 1231v3 for the CPU
https://linustechtips.com/topic/540356-help-build-pc-1000-bucks/#findComment-7158137
