HeyGuys
So this will be the first time I do a custom water loop. It's been a dream of mine to have one and I think I'm just gonna do it now. I currently have a green/black build (see pictures in sig) but I always wanted to have a white/black theme with custom loop. (I also threw a sneaky GPU upgrade in there)
So here's the list of parts I want to get:
I've gone with EK stuff because I think their stuff is good quality. Reason for PSU upgrade: Current one is over 2 years old and like 80+ bronze or some shit. About the Fittings: idk which ones to get/how many so deffo need some help there.
Please suggest better stuff/Give opinions about the list. Thanks!
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/539628-first-time-custom-water-loop/
you do need the backplate for your gpu too. if youre using the oem backplate of the 6g gaming card you have to leave 3 screws ouf of the block which makes the vrm not align perfectly with the block. other than that your list looks fine to me. the backplate costs like 20 euro.
IF YOU WANT ME TO REPLY TO YOU, QUOTE MY POST.
Fire Strike Score
5820K @ 4.8GHZ - 1.25v / Uncore @ 4.5GHZ - 1.2v / 3000MHZ G.skill 32GB Quad Channel / Asus Rampage V Extreme / 950 Pro Nvme / Sound Blaster ZxR  / 980 TI / Windows 7
if you are not planning on a bonkers voltage overclock on the CPU and GPU a single 280x45mm radiator will suffice. this will remove that single 120 which won't make much in improvement, adds another leak point, and usually crowds the i/o with unruly clutter.
Hmm. I wanted to get the MSI g6 because of the backplate. So I could just get a reference card if I'm going to buy a seperate backplate. Thanks for the tip!
yea i have the 6g gaming, its a great card but with the ek wb fullblock youll need the ek wb backplate. the oem backplate looks kinda cheap in person tbh, its just cheap plastic anyways.
Fire Strike Score
