FSX Steam frame cap ?
Go to solution Solved by AlwaysFSX,
Settings -> Customize
Slide to the right so it's on unlimited.
56afc6fedb437_fsxsettings.thumb.JPG.cac3
so im playing the game and im stuck at either 60fps outside or 30 fps in cockpit view.. any ways to remove that ?
https://linustechtips.com/topic/539107-fsx-steam-frame-cap/
In the original there was a built in frame limiter you could set to pretty much anything or just turn off.  Is it that?
https://linustechtips.com/topic/539107-fsx-steam-frame-cap/#findComment-7143275
Yup, it was that...
https://linustechtips.com/topic/539107-fsx-steam-frame-cap/#findComment-7144170
