Read/Write Speed for recording gameplay?
7200rpm of any flavor of drive should do the trick, but you're looking at the medium that the data goes through. USB3 or ESATA for external connectivity is probably the way to go. USB2 probably would be too slow. Firewire might be able to handle it, but I've not actively researched as of recent whether or not those actually are used anymore.
Other than the type of plug outside the computer case, ESATA is basically just an extension cord to go from your mobo to your device. Usually there is a plate that comes with whatever external drive you're using that you just plug into your SATA port on your mobo to the device, then slap the metal plate into a slot at the rear of your case. You might be able to get a PCI/PCIe card, but at that point, you might as well look at USB3 since it'd have more uses down the line.
