Does anybody know of any good Surface 3 body protectors (like a screen protector but for the body) to prevent the magnesium from getting scratched and damaged?
and where I can get them in the UK?
Gaming PC: Case: NZXT Phantom 820 Black | PSU: XFX 750w PRO Black Edition 80Plus Gold (Platinum) | CPU: Intel Core i5 4690K | CPU Cooler: BE QUIET! Dark Rock Pro 2 | MB: ASUS Sabertooth Z97 Mark S | RAM: 24GB Kingston HyperX and Corsair Vengeance 1866MHz | GPU: MSI R9 280X 3G | SSD: Samsung 840 Evo 250GB | HDD: 9TB Total | Keyboard: K70 RGB Brown | Mouse: R.A.T MMO7
Laptop: HP Envy 15-j151sa | 1920x1080 60HZ LED | APU: AMD A10-5750M 2.5GHZ - 3.5GHZ | 8GB DDR3 1600mhz | GPU: AMD  HD 8650G + 8750M Dual Graphics | 1TB SSHD
https://linustechtips.com/topic/538463-surface-3-body-protector/
that film would get annoying, peel and get dirt stuck. you are better off with a sleeve and just be careful when its out of the sleeve.
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/538463-surface-3-body-protector/#findComment-7136967
do you really need one? i have a case for my pro that I never use cause it would block some of the heat from dissipating. I've been using mine for 2 years without breaking it and I don't baby the thing. I would get a screen protector if you don't have one though.
https://linustechtips.com/topic/538463-surface-3-body-protector/#findComment-7136975
I got a fake carbon fiber skin for my sp4.  I like it,  it stops the body from getting scratches.  I noticed after 2 weeks of use some scuffs and scratches on the body.  The skin has held up for now.
I got it on amazon.  Just search for sp3 skins.
01010010 01101111 01100010  01001101 01100001 01100011 01010010 01100001 01100101
https://linustechtips.com/topic/538463-surface-3-body-protector/#findComment-7137128
