Android Stick Stuck In Bootloop
Go to solution Solved by iamdarkyoshi,
Okay, well nevermind, after two years it decides to work fine...
So I have a digitalsignage branded android stick. An older model. It bootloops when turned on. It has USB ports for keyboards and stuff, is there any keyboard combo that can make it enter recovery? Would something like this have recovery like an android phone would? It also has an SD card slot, which might be what is used to flash/update firmware. Anyway, its stuck in a bootloop, how can I fix it? Use percussive maintenance?
https://linustechtips.com/topic/538441-android-stick-stuck-in-bootloop/
